SpotlightInserting lighting devices
Tool
Tool set
Lighting Device
Lighting
The Lighting Device tool inserts an existing lighting device symbol, including both standalone and multi-cell devices.
To identify which symbol was used to create a lighting device in the drawing, right-click on the device and select Locate Symbol in Resource Manager from the context menu.
Mode
Description
Rotational Insertion
Inserts the lighting device with two or three clicks, depending on the view
Single Click Insertion
Inserts the lighting device with one click
Distributed Insertion
Inserts the specified number of lighting devices evenly spaced along a line
Lighting Devices to Insert
(Distributed Insertion mode)
Set the number of lighting devices to insert
Lighting Device symbol
Opens the Resource Selector to select a lighting device symbol; double-click the resource to activate it
Hanging Hardware symbol
Opens the Resource Selector to select a hanging hardware symbol; double-click the resource to activate it
Fixture Mode
Specifies a fixture mode for previsualization in Showcase or for export to an external program like Vision
Automatic Numbering
When toggled on, enables automatic numbering as objects are placed
Automatic Numbering Preferences
Sets the automatic numbering preferences
To insert a lighting device:
Click the tool and mode.
Click Lighting Device symbol on the Tool bar to select a symbol from the Resource Selector.
Click Hanging Hardware symbol on the Tool bar to select a symbol from the Resource Selector, or leave the option set to <None>, if no hardware is required.
For previsualization, click Fixture Mode on the Tool bar, select Other, and then select a mode; see Selecting a fixture mode. The DMX Footprint is set automatically according to the selected fixture mode, and cannot be edited.
To use GDTF data for Showcase or when exporting to a lighting console or visualizer (including Vision) specify the GDTF Fixture on the Object Info palette. For more information about GDTF, see Attaching GDTF data.
To automatically number lighting devices as they are placed, click Automatic Numbering on the Tool bar, and then click Automatic Numbering Preferences to set the preferences; see Numbering objects at placement.
Other numbering options include Numbering lighting devices by hanging position or Numbering Spotlight objects with the Spotlight Numbering command.
Lighting devices can be inserted independently, or they can be attached automatically to a rigging object; see Concept: Attaching loads to rigging objects.
Do one of the following:
In Rotational Insertion mode in Top/Plan view, click to insert the lighting device, and click again to set the rotation. (Shift-click to constrain the rotation to standard snapping angles.)
In Rotational Insertion mode in a 3D view, click to insert the lighting device, click to set the X rotation, and click again to set the Z rotation. The working plane assists with placement. If you are placing the lighting device on a truss, the light snaps to the truss chord and takes on the truss orientation, so only two clicks are required: one to place the light on the truss, and one to set the angular direction. The working plane assists with placement.
In Single Click Insertion mode, click once to insert the lighting device. The device points down, unless inserted on a truss, where it takes on the truss orientation (ignoring the roll angle).
In Distributed Insertion mode, specify the number of Lighting Devices to Insert from the Tool bar. Click to insert the first lighting device, and then move the mouse to set the angle and spacing of the remaining lighting devices. Click to place the lighting devices. If inserted on a truss, they take on the truss orientation (ignoring the roll angle).
Press the Option key (Mac) or the Alt key (Windows) at insertion to reposition lighting devices from the bottom truss chord to the top truss chord, when working in Top/Plan view. In an isometric view, holding the Option key/ Alt key inverts the hanging direction of the lighting device on the pipe/chord being snapped to.
You cannot use boomerang selection while placing lighting devices.
By default, the active label legend is applied to the lighting device.
If a lighting device symbol is accidentally inserted by the Symbol Insertion tool, the lighting device functionality will not be present. When correctly inserted, the Object Info palette displays "Lighting Device" for the selected device.
Once lighting devices have been inserted, they continue to associate automatically with the nearest rigging object within the Pick Radius set on the Spotlight preferences: Loads and Rigging pane. To prevent lighting devices from attaching to a new rigging object when moved, disable automatic positioning on the Loads and Rigging pane.
Changing device properties
Setting up label legends
Inserting hanging positions
Spotlight preferences setup
Creating a lighting device from an existing symbol
Concept: Working planes
Concept: Power schematics
